Hello all,
There's a specific level with a corresponding floor plan which is shown on my floor plans browser (Level 2). However, that level line is not showing in any of my elevations, sections or 3D View.
Tried to check if it was hidden, or in a turned-off workset but nothing.
(I'm working on Revit 2019)
Any feedback is appreciated it!
Thank you.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Thank you for the prompt response, but I tried that and it did not work.
I was able to make it show in 3D and elevations somehow, but still missing on the new sections I create it. Not sure what approach to take!
I happen to run into this issue as well and it turns out to be the work set is not active. This question is two years old so I guess you must have already solved your issue, but figured it may be helpful for anyone in the future.
3 years on from your "late" response, and this fixed my problem. Tried adjusting datums and scope boxes but your answer fixed it. Moved the level to the correct workset and now it shows up. Thank you!
