For the project I'm working on when I create new views (say, elevations or sections) some of the level labels show up by default on the left and some on the right side,'
I thought I had cleaned this all up by correcting the building sections with the tools propogate extents, reset to crop, maximize to 3D extents, reset to 3D extents etc.
Also set the tick boxes so the level heads and levels appear on both ends of the building section.
The thinking was then I can go back in later and turn off whatever I want to as some level heads for any given building section may end up on left side and some on right.
Regardless, want everything either to by default be on the right for everything, the left for everything, or on both sides.
I'm wondering if because I may have started drawing the levels on left or right inconsistently then turning on/ off a particular end to get to conform with the others if this could have caused the issue.
Don't want to keep turning on and off this stuff all the time.
Any help sorting this out is appreciated.
