Level head cannot be selected.
niloufarc
Message 1 of 9
niloufarc
I am new Revit LT-19 user 4 months only. I have problem with level head since yesterday and can not select and pick only 2 of level heads of 1st and 2nd floors, the rest of the floors level heads are OK. I have not changed any setup. I also tried the file with my colleague's computer it looks ok there no problem with selecting and clicking on the those 2 level heads. If anybody knows what is the problem I will appreciate the help.
Accepted solutions (4)
Replies (8)
Message 2 of 9
cbcarch
Are the Levels from a Linked model? Are they Pinned? On a different workset? Filter?
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 3 of 9
niloufarc
 No, They are not filtered/pined/work set. They are OK in my colleague's computer and editable.
Message 4 of 9
cbcarch
See if the Levels have been Copy/Monitored from a Linked file.
Then, check Worksets--you may be trying to select the Linked file's Levels, instead of the Copy/Monitored Levels, which could also be on a different workset.
Cliff B. Collins
Message 5 of 9
niloufarc
Unfortunately the problem is not any of what you said. because the file itself is working very well in my colleague's computer. I cannot find the problem. It might be a bug or LT problem?
Message 6 of 9
Being able to select pinned elements is computer dependent, not file dependent. So, check yours and make sure you allow the pinned elements to be selected.
Message 7 of 9
niloufarc
Yeah, that was it. Have no idea how they got pinned. thanks alot.
Message 8 of 9
cbcarch
Ummmm......maybe accept my solution?
Cliff B. Collins
Message 9 of 9
niloufarc
Sorry, i have no idea how those levels lines got pinned. Thank you very much.
