I am a structural engineer with the task of adding a new access walkway to an existing platform. We have various elevations called out for the new/existing steel and I would like to edit the elevation marker at the existing level to not have the filled in quadrants that the default level marker uses. See attached screenshot. This is a standard we've been using for years, so I'd like to find a way to easily integrate it into our templates. So, is there a way to create a "toggle switch" within the properties, parameters or family that will turn on/off the quadrant fill effect"? If not, is there an easy way to replicate the "Level Head - Circle" family, call it "Level Head - Circle (Existing)", change it to look the way we want, and assign it to whichever levels apply? Is there a way we can make it viewport specific, so that if we have existing and new steel at the same elevation we can adjust the level marker as needed on a detail-by-detail basis?
Those screencasts are extremely useful if someone has the time ![]()
Thanks in advance!
Michael
TLDR: What's the easiest way to change a level head to have four empty quadrants?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
I am wondering about the workflow. Are you working from an as-built, or are you modeling both conditions in the same project. But, yes, you can use two distinctive level markers in the same project, but...do you really want two levels, two structures occupying the same space in the same project?
