Is there a way to display a level name without the elevation value, aside from hiding the elevation in view and making one with the level annotation and a gridline?
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
@Anonymous: I thought for sure this tread would be closed out by now. Do you know how to apply a different Symbol Head to a Level?
I do I just cant use the file you sent because it is newer than 2017, which the project I'm doing is in, so I just haven't gotten to messing with it
Not hard to replicate.
1. Open up your Level Head Family.
2. Associate the Visibility Parameter of the Elevation label to an On/Off Parameter in the Family
3. Create two Family Types: one Type with the On/Off Parameter checked, and the other Type with the On/Off Parameter unchecked.
4. Load into Project and use.
