level change
level change
BIM_Dreamer
Message 1 of 11
level change
BIM_Dreamer
how to change my level of FFL 102.300 to FFL 2.300 without affecting my model. thank you
Replies (10)
Message 2 of 11
Levels can have Elevation based on project base point or survey point.  Edit your Level type and see what it's Elevation based is.
Message 3 of 11
BIM_Dreamer
elevation base is survey point. thank you
Message 4 of 11
BIM_Dreamer
i have changed to project base point and 1st storey become FFL 0.000, how to make FFL 2.30 ?
Message 5 of 11
Have you tried to change to Project base point?
Message 6 of 11
BIM_Dreamer
how?
Message 7 of 11
BIM_Dreamer
change to project base point here is the result
Message 8 of 11
Okay, either move the project base point down 2.3 m and set the level type elevation base to project base point, or move the survey point 100 m up and see the level type elevation base to survey point.
Message 9 of 11
BIM_Dreamer
not sure if i'm doing correct one? manage to change 1st storey level as per your instructions? now how i'm going to move my project base point (elevation) as same as my 1st storey level? thank you
Message 10 of 11
Project base point is 100 m above Survey point which is correct. Why do you need to change it any further?
Message 11 of 11
dyp4f
In the last image, I can see 2 very large numbers for N/S & E/W coordinates regarding the Project Base point.
Could that pose any problems to the Revit Model ?
