I created a floor plan on level 1 but when I select level 2 to view it. I don't see it. My walls on level 1 all go up to level 2. and my roof level is present in elevation as well. I'm trying to install a roof but nothing shows in level 2 or the roof level? REVIT 2015
@Anonymous hello, check your view range from level 2 and adjust it to negative value to view it. thanks
The wall are actually up to the roof level when I view the walls in south elevation. So they are pass level 2
this is what my view range says, which numbers to change negative?
Well you initially said that your Level 1 walls all go up to Level 2.
There are MANY reasons walls might not show up in a view. Can you post your project file for us to use? That would be the simplest way for us to identify what's wrong.
