Level 1 view
5 ANTWORTEN 5
Nachricht 1 von 6
qixing.chenNYA88
316 Aufrufe, 5 Antworten
Level 1 view
I'm working on curtain wall doors. I want to hide the second door's frame in the level 1 view. The second model's view range and Visibility/ Graphics Overrides are the same as the first one. Do you know which setting I should change in order to no show the second door's frame?
Thanks.
5 ANTWORTEN 5
Nachricht 2 von 6
mhiserZFHXS
als Antwort auf: qixing.chenNYA88
In the family editor, select the elements you want to hide in plan view. Go to the Visibility/Graphics Overrides in the properties menu, and uncheck Plan/RCP.
Nachricht 3 von 6
qixing.chenNYA88
als Antwort auf: mhiserZFHXS
Thank you for the quick response.
Sorry, I didn't explain it clearly. I want to have a kind of cut view in
level 1, don't show the rail but still can see the right frame. It should
be the same as the first picture in the original post.
[image: image.png]
Nachricht 4 von 6
mhiserZFHXS
It should be the same process. Are you looking at these settings in the family editor or project editor?
Nachricht 5 von 6
Share the door family here.
Nachricht 6 von 6
qixing.chenNYA88
I checked the family and also the view range but it doesn't work.
