Hi, anyone knows why I can't see Level 0 in floor plan list?
Thanks in advance
Gelöst! Gehe zur Lösung
Gelöst von lim.wendy. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Did you create one? Did you create a Plan View from the Level? View Tab=>Plan Views=>Floor Plan.
I don't remember.....I might have created everything in 3D. I can see all levels in plan view Level 1,2,3,4 but no level 0.
Please help
Go to the View Tab and press Plan Views and then press Floor Plans. Do you see "Level 0" listed?
First thing you need to do thought, is to go to an Elevation View and Add a Level. If you haven't done that already, you are given the Option to Create a Plan View on placment of the Level. Look on the Option Bar when placing the Level. See "Make Plan View"? Is it checked?
If you already have a Level named "Level 0" and it is black, then do what I said before to create a Plan View for it.
@Anonymous wrote:Thank you so much. It is sorted. I appreciate your effort and time.
You're welcome. All good now? What did you end up doing?
Hi @Anonymous,
Welcome and thanks for reaching out to the forum. Looks like @barthbradley provided you a solution, for now, I am going to mark this as "Solved".
If the suggestions helped you, please hit the "Accept Solution" button, as it helps makes the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you. ![]()
