Length Parameter formula. Width can not exceed Height.
1 ANTWORT 1
Nachricht 1 von 2
rlo6LRKS
1455 Aufrufe, 1 Antwort
Hi everyone!
Is there a formula that limits one parameter (Width) in accordance with another (Height).
I have a furniture family, where the end user can edit both Height and Width. But I want to insert a formula that does not allow them to put a Width that's bigger than Height. I am using Revit 2018.
I tried with this:
        =if(Condition, Result-if-true, Result-if-false)
e.g. =if(Width>Height, Height, Width)
But since I don't have a Min and Max value this does not really apply.
Beschriftungen (3)
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: rlo6LRKS
So you want two Width Parameters - one where the user enters a value and the second one has the formula and drives the actual dimension.
Width 1 (User-Entered Value)=10
Width  2 (drives the Dimension the changes the width of the geometry)=If(Width 1>Height, Height, Width 1)
....you can do Min/Max this way: =if(or(Width 1<5, Width 1>10), Height, Width 1)
Revit Formulas for "everyday" usage (revitforum.org)
