Length of the wall.
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
m.kopaniaAQZ65
518 Aufrufe, 7 Antworten
Length of the wall.
As I understand, the only way to obtain real length of the wall, which is connected with other walls, is by creating parts?
Otherwise it give me the length between core center lines of side walls, which is not correct if we want to obtain real length of wall type.
Beschriftungen (2)
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: m.kopaniaAQZ65
Disallow auto-join and draw it length you want it.
Nachricht 3 von 8
May not be the only way but certainly a good way without changing how walls are drawn and joined.
Nachricht 4 von 8
MachielAEC
Also found to have corner walls to be miter joins increase the accuracy instead of but joins.
Depending on where and how you are calculating this, I had to reverse engineer the length value with this formula in my schedules - area / height = lenght
Again, not perfect but can help.
Machiel Odendaal
---BIM Enthusiast---
Nachricht 5 von 8
m.kopaniaAQZ65
als Antwort auf: MachielAEC
Thanks, this are very helpfull.
Nachricht 6 von 8
MachielAEC
If you found an answer that helped, please accept the solution provided.
Helps future people looking for answers and also the community providing solutions.
Machiel Odendaal
Nachricht 7 von 8
Using parts as you described in your original post is a better, if not the best, approach.  If it is your idea then feel free to pat yourself on the back.  If someone else gave you the idea then they deserve a proper thank.
Using a formula only works if the walls have no opening, not attached to a sloped roof or floor, not profile edited.
Nachricht 8 von 8
MachielAEC
als Antwort auf: ToanDN
At the end of the day there are so many ways of doing the same things and really depends on the outcome required.
Machiel Odendaal
