Length of Custom Curtain System Panel
1 ANTWORT 1
Nachricht 1 von 2
282 Aufrufe, 1 Antwort
I am making a big shelter of a perforomance platform.  I use the curtain system to divide the panels by the using the custom grid line.  In order to have a unite design, triangle and rectangle panels are created, most of the panels do not have same area and length.  I used the standard panel schedule to obtain the area of each panel, but I cannot find out the length and the no. of side of each panel(3 or 4 sides).
Billy
Tags (2)
1 ANTWORT 1
Nachricht 2 von 2
Alfredo_Medina
als Antwort auf: Anonymous
@Anonymous
Welcome to the forum. I see that this question has been without an answer for 5 months. Had you posted some images, that would have improved the chances of getting an answer. If is't not too late, please provide more information, images, or a sample Revit file, etc. What you are asking sounds possible, using instance length shared parameters.
