Legends. appears diffrently in facade and as a legend
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
797 Aufrufe, 7 Antworten
Any idea how to remove the "opening lines"
It's a fixed window, as a legend it appear to be a window with hinges
The window appears correctly in section/facade on the sheets (I can change in the settings;  choice of opening function in the sheets but as a legend it only appears as a window with hinges)
Any idea how  can control "choice of opening function" in legends or remove the lines like in the image below
Thank you
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: Anonymous
Are the swing lines controlled by type or by instance?  Set it to a type parameter and turn off for the fixed window type.  Then use that type for legend.
Nachricht 3 von 8
als Antwort auf: ToanDN
Thank you for your reply
Can you please guide me how I do this -->"Set it to a type parameter and turn off for the fixed window type"
Thank you
Nachricht 4 von 8
Does the window have a Visibility Parameter for Elevation Swings Lines or are they not Visible in certain Detail Levels?
Nachricht 5 von 8
als Antwort auf: barthbradley
In elevation I can change add and remove the swing lines by changing the number (see red mark) that works perfectly on elevation but the problem I have is that in Legends I cant find that option (to add or remove the swing lines)
Nachricht 6 von 8
Try setting the default Visibility condition to invisible and reload the Window into the Project.  That should remove them in Legend View.
...BTW, you want to check override existing version/parameters upon reloading. Might not be ideal.
Nachricht 7 von 8
Ah, I get what you want to do. Go with @ToanDN 's suggestion. Create Family Types for each operation (e.g. fixed Type with no Swing Lines and hinge Type with Swing Lines).
Nachricht 8 von 8
Thank you very much
