Legend in Sheets scale "As indicated"
marco.defina
Message 1 of 16
marco.defina
i have in every sheet a legend...So in my plan i see "as indicated on the title block...
it's possible to not read the scale of the legend???
I created the entire legends in scale 1:1
BIM Manager - HVAC and Plumbing designer https://www.autodesk.it/content/dam/autodesk/www/products/responsive-imagery/responsive-badges-compare/2019/navisworks-manage-2019-badge-75x75.pngApp AutoCAD per dispositivi mobili premiumNavisWorks Simulate3ds Max___________________________________________________________________________
Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums.
Accepted solutions (3)
Replies (15)
Message 2 of 16
ennujozlagam
Hello you can here below previous thread some explanations same issue as yours. Thanks
https://forums.autodesk.com/t5/revit-architecture-forum/multiple-scales-on-a-sheet-quot-as-indicated...
Message 3 of 16
maybe you could try putting the legend into your sheet template? - not as a legend.......
Message 4 of 16
kadmonkee
create a viewport with the Detail Title turned off
select your view , go to EDIT TYPE button in properties
duplicate the current TYPE rename it and change the Show Title parameter to NO
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Message 5 of 16
chrisplyler
kadmonkee,
That won't prevent the SHEET'S scale parameter from picking it up.
If the other views on the sheet all have a matching scale, then the sheet's scale parameter should match it. Only if the views on the sheet have scales that don't match, then the sheet's scale parameter will read, "As Indicated."
The only solution here (if you want to actually use a legend view)  is to make your legend view scale match the scale of the other views on the sheet.
Message 6 of 16
kadmonkee
if I am understanding the issue correctly this method does work
if it is a matter of not seeing the title and or scale of the Legends View it does not matter what the scale of the legend view is
Original Legend view is set to 12"=1'-0"
copy 1 = 3/4"=1'-0"
the 2 on the right are duplicated views with the Title turned off
see image
thank you
Message 7 of 16
OP is asking about the piece of label on the Sheet title block, not the Legend view's title. The only way to prevent the Sheet saying Scale as indicated without removing the label is having all views including legends with the same scale.
Message 8 of 16
kadmonkee
I misunderstood the issue then.
is this what the OP is looking for?
thank you
Message 9 of 16
@kadmonkee  Correct.
Message 10 of 16
kadmonkee
ok I got it now thanks
@ToanDN @chrisplyler
thank you
Message 11 of 16
marco.defina
This is ridicolous, i need to have a legend for every scale of Sheet? Smiley Sad
What utility has legend with different scale if is everytime on sheet, that is in 1:1 scale!
Thanks anyway
Message 12 of 16
marco.defina
I found another solution, i create the legend in an annotation (with the time to recreate the subcategories and the hatch as the project), so the legend change in function of the scale....
Message 13 of 16
Thanks that worked perfectly.
Message 14 of 16
luciana.in.architecture
Community Visitor
Community Visitor
Can you please elaborate in a way to instruct me?
You question was a very important one.
Thanks.
Message 15 of 16
ben9Y6CK
Observer
Observer
This is certainly the best way to do it, still in 2024.
Could the sheet not just have a tick box or similar to choose to ignore legend type elements etc.?
Message 16 of 16
DanielKP2Z9V
Sorry, what do you mean by "create the legend in an annotation"?
