Legend Component Difficulties
2 ANTWORTEN 2
Nachricht 1 von 3
349 Aufrufe, 2 Antworten
I have recently encountered a problem in Revit 2018 with the Legend component. A few days ago it was working perfectly fine and then one day it started giving me a green X and no drop box showing the different options. This is not something restricted to the job I was working on as when trying to make a new job I would get the same outcome. Has anyone else encountered this problem and is there a solution?
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
 Hi there,
The green x you are seeing is the cable tray legend item - could you provide a screenshot of your screen.
It's placing in a Legend Component, it's just the wrong one.
If you could send a screenshot of you placing a legend component I can see what your environment looks like and assist you further from there
Nachricht 3 von 3
Thank you for your response but we were able to fix the issue by repairing Revit. It seemed to be a problem with the Dropbox.
