Trying to create a formula that states, if BBS_ply Panel(default) is not checked on then BBS_Fire Rated Panel( default) must be on....
I thought I would get away with : not(BBS_ply Panel(default))... but I get a error message abave.
Can anyone help me to write the correct formula to achieve my goal.
Thank you!
Gelöst! Gehe zur Lösung
Gelöst von dpatriotaW9CR9. Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Remove the (default) from the formula
This is not part of the parameter name. It is more of an image indicator that it is an instance parameter
