LEED IEQ 8.1 prescriptive
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
htews
560 Aufrufe, 5 Antworten
anyone figure out how to calculate/schedule 8.1 prescriptive calculation using Revit?
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: htews
Nachricht 3 von 6
htews
als Antwort auf: Anonymous
LEED credit manager doesnt work anymore.
discontinued unless i'm missing something else.
Nachricht 4 von 6
htews
that's ok.  I think I figured it out.
Nachricht 5 von 6
How? u shud share it.
Nachricht 6 von 6
htews
using Revit 2018.2:
(not the correct way of doing things, but this is how I did it)
first started with this thread that @ermiastessema solved and went from there.
LEED 8.2 - Views - Visibility Analysis
create a phase VIEWS and a workset VIEWS, to work your views using Rooms/Spaces/Zones and then schedule the Views calculations
Then create a new phase DAYLIGHT and workset DAYLIGHT, and add new Spaces.  the new Spaces will be the area that is within the daylight zone.
then with the help of @ToanDN in the thread schedule panels.  with this help, I created a material takeoff schedule to calculate the windows for each space.
Once i got that to work, I added a 'window area' instance parameter for Spaces, I then create a new schedule that will do the Daylighting Zones calculations.
Hope this helps.
*if it does, please give Kudos or feedback of this doesn't work*
