Leaders change & span direction
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
glkirk
661 Aufrufe, 3 Antworten
When I detail things using text and add leaders, with the straight leaders, when I come back to the view later, the straight leaders have shifted crooked a bit. Any thoughts?
Also, no mater how I change the span direction when making a floor with direction spaced lines, it won't change the lines. Am I missing something or should I just set up the lines at 90 degrees?
Thanks!
3 ANTWORTEN 3
Nachricht 2 von 4
glkirk
als Antwort auf: glkirk
Bump
Nachricht 3 von 4
- If the text size changed then straight leaders can get crooked and need readjusted.
- Span direction symbol changed according to the span direction here.
Nachricht 4 von 4
ryley.g.h
als Antwort auf: ToanDN
Changing your view scale also affects this as your text size will change when the scale is changed (it acts just like CAD annotated text).
