Hello. I would like to reduce the leader arrowhead - filled dot from 3mm to 1mm but on my list there are not more available ones. Please see image attached. Thanks.
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
@Anonymous
Back in the project select the leader/tag >> Go to Edit Type on the palette >> and the 1mm Dot Filled should now be in the drop down list.
