Hi. Is there any solution to change line weight of specefic layer of wall simultaneously in all views?
and also one other thing: Is there any way to change line weight of structural layer of a wall in a view without changing other walls in that view?
Gelöst! Gehe zur Lösung
Hi man!
You can do this in the "Visibility\Graphic" overrides.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Dmitriy Semko.
Hi!
You can create View Templates. With this tool, you can preset your configurations for any view and just apply it to them.
To do that, access the ribbon View > View Templates > Manage view templates. You can duplicate and rename any of the existing view templates and adjust the scales, the detail levels, the models and annotations overrides etc. So, inside the V/G Overrides Model, you can find the category Walls and change the lines when these elements are cut. You can choose the line thickness, color and pattern.
For the second doubt, you'd have to create Filters inside these View templates. With the filter, you can make elements with diferent kind of representation, even if these elements are from the same type.
If your problem has been solved, please click on Accept as Solution. Then others users can take benefit of it.
Felipe Góes
Autodesk Instructor
'and also one other thing: Is there any way to change line weight of structural layer of a wall in a view without changing other walls in that view?'
if it is just one wall then the the simplest way is to use Linework tool and do it manually for a selected wall.
Cut Line Styles in V/G dialog is a global solution that can be included in view template but it cannot be controlled by filters in a view in order to apply overrides only to selected elements in a view.
You cannot use filters to override lineweight of individual layers by their function in a wall structure.
Hello there!
I know this solution, and I was wondering, is there a way to set up/modify the cut line layers globally within the project? (instead of going through the templates one by one) I checked within Object Styles and I can't find anything.
