Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Lattice Wall System
BigPicture045
Lattice Wall System
BigPicture045
I need to model the lattice work seen the in the reference image below. Note that I need the lattice follow the stair tread/riser aswell.
Not sure where to start on this one.
A material with surface pattern and cutout for rendering may suffice.  If you really want to model it, use curtain wall with rotated grids.
I'm with @ToanDN. I wouldn't model lattice. If you want a graphic surface pattern for non-realistic representations - other than a simple diagonal cross-hatch pattern - you can try a lattice model hatch pattern like the one attached herein.
syman2000
You can create Lattice out of curtainwall. See attached.
or...
Alecia_aldrichJG5AG
Community Visitor
Community Visitor
YOU ARE A HERO!!! THANK YOU!!
Alecia_aldrichJG5AG
Community Visitor
Community Visitor
YOU ARE A HERO FOR THIS!!! THANK YOU!!
