So, the Revit deployment of Latest version for Revit 23 should deploy the build number 20221122_1550
But it does not - the build 20220503_1030 is deployed, with the hotfix 23.1.1 not installed.
Troubleshooting the latest update, we are instructed to remove the 'Autodesk Identity manager' to allow the latest update to install. (https://knowledge.autodesk.com/support/revit/troubleshooting/caas/sfdcarticles/sfdcarticles/Install-...)
In fact, on this page the custom deployment that does not work is described at the end of the article.
I ask this - could we please have the ability to select the components in greater detail that we want installed? IF The identity manager causes this issue, why can we not have a modified install where this is applied last, so it does not interfere with other aspects of the deployment? IF it is known to be an issue, why not provide the modified bat for the deployment?
Why don't you ask this in the Licensing and Installation forum?
