Latest Onmi Class NUmber list
Hi, I am getting multiple OmniClass number list as below. 1. Autodesk Revit Omni Class Taxonomy file 2. Autodesk Seek Website( version 1.0 3. Autodesk Revit Software Library So little bit confuse which is correct? It will great if anybody share latest and correct Omniclass number list, Thanks
Hello @Anonymous,
Here are the updated OmniClass Numbers :
http://download.autodesk.com/us/revit/OmniClassTaxonomy.txt
Download the attached file and follow the procedure to update the file in the Revit installation.
Note: The AppData folder is a hidden folder, so you need to first enable the viewing of the hidden folders on your system before performing the procedure.
  1. Navigate to C:\Users\<current user name>\AppData\Roaming\Autodesk\REVIT\<product name and release> Example: "C:\Users\<DoeJ>\AppData\Roaming\Autodesk\REVIT\Autodesk Revit 20xx".
  2. Rename existing "OmniClassTaxonomy.txt" to "OmniClassTaxonomy_bak.txt".
  3. Copy the downloaded file to this location. Repeat this process for each user on this local machine.
  4. In addition, copy the file to the following location. This step ensures that any new future users of this computer will get the updated file. C:\ProgramData\Autodesk\<product abbrevation>\UserDataCache Example: "C:\ProgramData\Autodesk\RVT 2015\UserDataCache.
  5. Repeat process for each Revit product installed (RAC, RME, RST....) as needed.
Note: When using the updated OmniClass file, category sorting is not available. You must manually navigate to the correct category to assign an OmniClass number.
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received!
Best Regards,
M.H/
