Lateral Offset of Text in Linear Dimension
4 ANTWORTEN 4
Nachricht 1 von 5
Matias_Halac
586 Aufrufe, 4 Antworten
Hi!
I could find where to set the lateral offset of the dimension text. I attached an image in order to clarify the situation. I already find the vertical offset, but dont know how to move it to the right.
Does anybody knows how to?
Thanks!
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Matias_Halac
Hi @Matias_Halac.
From the image you attached i assume it to be a symbol that you are trying to adjust? If this is the case, 'Edit' the familiy and ensure that the text is in the correct position and adjust the limits in the family and then reload back into project.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Nachricht 3 von 5
Matias_Halac
als Antwort auf: Anonymous
Thanks for the answer!
Actually, is not a symbol. Is a linear dimensión, that is measuring absolute
dimensión from an axis.
Thanks!
Nachricht 4 von 5
You could use Ordinate dimensions.
Nachricht 5 von 5
Hi @Matias_Halac.
The only solution i can think of is that the text was moved. If you click on the text, there as a dot below the text that can be shifted. Try doing this. Other than this i'm not sure.
I hope this helps.
Kind Regards,
Andre
