Large bounding box in arrayed family.
3 ANTWORTEN 3
Nachricht 1 von 4
PEB73
356 Aufrufe, 3 Antworten
I created an array using a nested family, worked ok but the label showing the number of objects in the array is displaced and there is a large bounding box.  The image attached explains more clearly I hope:
I have had a look at the family file of the component I am trying to "array" but can't see any objects that might be dragging the limits out to this extent. Any suggestions on what could be the cause? Thanks.
Beschriftungen (1)
3 ANTWORTEN 3
Nachricht 2 von 4
Mike.FORM
als Antwort auf: PEB73
how are those blade elements created? Is it made using a sweep and a profile? Check the profile to make sure there are no ref planes drawn in the profile sketch off in the distance. The same can be said if it is an extrusion. Make sure there are no ref planes in the extrusion sketch.
Nachricht 3 von 4
RDAOU
@PEB73
In the family there is an array and it is going haywire ... how to fix would be hard to tell without the family
Nachricht 4 von 4
PEB73
Thanks for the replies. The family was created from a sweep. I couldn't find the problem and ended up recreating the family from one that was working. This fixed the issue.
