Hi everyone,
I need a sense check on a laptop I am looking to buy for architecture work.
Its the 'MSI Katana 15 B13VGK-1404NZ 15.6" FHD 144Hz i9-13900H 32GB RAM 1TB SSD RTX 4070 Win11 Home'
Using Revit + Enscape mostly. (Adobe suite, Rhino on occasion).
Is this MSI laptop a good choice? (Not looking for top of the line obviously, but just need to know Im not getting something that's already outdated)
Would it handle larger revit models (400-600mb) without any issue?
Thanks everyone, I'm not so tech savvy so really appreciate any help!
Mike
Gelöst! Gehe zur Lösung
Gelöst von Toan_RLA. Gehe zur Lösung
Looks okay. You might to get 64GB RAM if you will have larger models with links. 1GB SSD is a bit low by today standards. They are cheap to upgrade though.
https://forums.autodesk.com/t5/revit-architecture-forum/laptop-for-revit-and-autocad/td-p/7761950
