Hi
I need to buy a new laptop as my current one has broken.
I am considering the HP Pavilion 15-CW0016AU - can you advise if this laptop is suitable for running Revit 2017
https://www.harveynorman.co.nz/computers/laptops/hp-pavilion-15-cw0016au-laptop.html
thanks, Celine
You can check below if your specifications meet the requirements to run revit. Thanks
Just bought this bad boy at microcenter for 2399 plus tax in Texas.
They offer 6 months no interest financing if that helps.
https://us.msi.com/Laptop/GE75-Raider-8SX/Specification
GE75 Raider-021
The 021 option is the best version it has 2 512 SSD drives in RAID mode which makes it super fast. Total hard drive space is 2T.
It also has the RTX 2080 witch gives you new ray tracing cores.
Try using lumion for renderings hopefully it will eventually utilize the RTX cores once their drivers are updated.
https://forum.lumion.com/click-here-if-you-have-not-got-lumion/graphic-card-276221/
I bought it on sale yesterday.
You could also go with the 15 inch version for 1699 but it does not have RAID hard drive support. I think Newegg also has no interest financing options as well.
Both computers will set you up for the future.
John
Hi @Anonymous
Welcome to the community! I see that you are a new visitor.:)
Please see this thread: https://forums.autodesk.com/t5/revit-architecture-forum/new-laptop-for-cad-and-revit/m-p/8069335#M198687
Hope that is helpful!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
You will want a minimum of a 512 gb SSD ...that 256gb is going to fill up fast and it will run very slow due to lack of memory.
