Laptop for Revit and AutoCAD
18 ANTWORTEN 18
GELÖST
Nachricht 1 von 19
19735 Aufrufe, 18 Antworten
I have a question regardin laptops suitable for autodesk products, first and foremost för Revit and AutoCAD.
I am looking for a new laptop for my girlfriend, who is a student and needs to be able to run Revit and AutoCAD smoothly.
I have found 2 laptops that I think might be good for the intended use, and would like to get the communitys input on which one I should opt on.
Dell inspiron 15 7000
8th gen Intel® Core™ i7-8550U CPU (8 MB cache, up to 4,0 GHz)
8 GB RAM DDR4 2 400 MHz
512 GB SSD
Windows 10 64-bit
NVidia GeForce 940 MX 4 GB GDDR5
Dell inspiron 15 7577
7th gen Intel® Core™ i7-7700HQ, 4 cores (6 MB cache, up to 3,8 GHz)
16 GB DDR4  2 400 MHz RAM
NVIDIA® GeForce® GTX 1050 Ti 4 GB GDDR5
Windows 10 64-bit
1 TB harddrive
The 7577 seems better, but costs about 300 dollars more than the 7000.
Is it worth the extra money? (We are on a budget, since she is a student).
Thank you in advance!
18 ANTWORTEN 18
Nachricht 2 von 19
dzanta
als Antwort auf: Anonymous
See below:
8th gen Intel® Core™ i7-8550U CPU (8 MB cache, up to 4,0 GHz)..........THIS IS FINE
8 GB RAM DDR4 2 400 MHz ..........GO WITH 16GB AT LEAST
512 GB SSD..........THIS IS FINE (TRY TO GET THE SAMSUNG 850/860 PCI M.2 CARD)
Windows 10 64-bit..........THIS IS FINE
NVidia GeForce 940 MX 4 GB GDDR5......CHECK GRAPHICS CARD FOR REVIT/AUTOCAD 2018 COMPATIBILITY...TRY NVIDIA QUADRO P2000)
7th gen Intel® Core™ i7-7700HQ, 4 cores (6 MB cache, up to 3,8 GHz)..........THIS IS FINE
16 GB DDR4  2 400 MHz RAM ..........THIS IS FINE
NVIDIA® GeForce® GTX 1050 Ti 4 GB GDDR5......CHECK GRAPHICS CARD FOR REVIT/AUTOCAD 2018 COMPATIBILITY...TRY NVIDIA QUADRO P2000)
1 TB harddrive..........THIS IS FINE
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Nachricht 3 von 19
als Antwort auf: dzanta
Thank you!
Mainly I am a bit worried about the graphics card. The ones listed above arent om the certified/recomended list on autodesk, but I have seen them as viable options on other forums.
Does anyone have any experience with those particular GPUs?
GeForce 940 MX och GeForce 1050 Ti?
Nachricht 4 von 19
dzanta
I run the GTX 960M on my DELL XPS....it has minor hiccups running Revit but runs AutoCAD fine.
Nachricht 5 von 19
dgorsman
"Not certified" is not the same as "won't work".  They only test the workstation cards.
I'd recommend the second one for a few reasons.  8 GB isn't enough for anything other than web surfing these days, let alone technical design software.  You'll want the newer model graphics card as it supports the newer features in the latest releases.  They are also far more power efficient.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Nachricht 6 von 19
cc4535
The Ti is a workhorse GPU, in my opinion, the only way to go with the two options you have.
Chuck Conley
M3 Engineering
Nachricht 7 von 19
Viveka_CD
Hi @Anonymous
Welcome to the Autodesk community.Smiley (fröhlich)
See this thread which discusses options for your query.
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you,
Nachricht 8 von 19
ARQ-CAMILA.PORTEIRO
als Antwort auf: Viveka_CD
HI EVERYONE! please i am looking for a computer that supports construction software with ease. Revit, Autocad, revit plugins, all Adobe suire (photoshop, indesign, ..... )    Would this be ok?  the issue im having is i cant find a computer this good , in a smaller size..... I was more in the need of 11 inches  or 13 the most.
thank you all!!!
  • Precision 5520
  • Intel Core i7-7820HQ
  • Windows 10 Pro 64bit English
  • 16GB, DDR4-2400MHz SDRAM, 1 DIMMS
  • Nvidia Quadro M1200 w/4GB GDDR5
Nachricht 9 von 19
sorry it is a DELL computer ..... model: precision.
Nachricht 10 von 19
Viveka_CD
als Antwort auf: ARQ-CAMILA.PORTEIRO
Hi @ARQ-CAMILA.PORTEIRO
As the first step, please see the system requirements and recommendations for the Revit product line. A list of certified cards can be found on the Autodesk Certified Hardware page.
Nachricht 11 von 19
Hello Friends! I am love to play games and recently I bought a Dell Inspiron i5577 laptop to use for this purpose now I am looking for a laptop that can help for Revit and AutoCAD software, I was taking a look at this Best Laptop for Heavy Applications - Lenovo ThinkPad P52 15.6" inch screen from this, But it is a little bit expensive. Any clue?
Appreciate your help!
Nachricht 12 von 19
jbowlesE4C6Z
Curious if you ran the Revit RFO Benchmark and what the results were on the Dell Inspiron
https://www.revitforum.org/hardware-infrastructure/35955-rfo-benchmark-v3-x.html#post191932
Nachricht 13 von 19
jbowlesE4C6Z
Dzan,
Have you run the RFO Benchmark tests on your XPS 15?   I'm curious what the results were.
Nachricht 14 von 19
dzanta
als Antwort auf: jbowlesE4C6Z
sorry....I have not ran that benchmark.  The system is currently about 4 years old now I think...
If you want me to run it, let me know and I will post the results.
Nachricht 15 von 19
hamza.rehman441240
Hey guys, could someone point me towards a benchmark/analysis is i7 9700k processor would be better for Revit 3d? Also, suggest me compatible motherboard. Because I'm looking to building a machine to work on large-scale PV projects on it, any help would be great, thanks in advance!
We Will also be using regular AutoCAD on it
Nachricht 16 von 19
semhustej
als Antwort auf: hamza.rehman441240
Why are you building a workstation on a two generations old CPU architecture? I would recommend using the newest one.
You can read this recent article:
https://aecmag.com/workstations/11th-gen-intel-core-vs-amd-ryzen-5000-for-cad-bim-beyond/
Tom
Nachricht 17 von 19
richardsasser
DO NOT BUY an HP ZBook - with the following configuration: Intel Core i7-9850H, 64 GB RAM 1 TB SSD, Intel UHD Graphics 630, Windows 10 Pro, 15.6 Inch Screen
FREEZES and CRASHES !! Terrible choice for Autocad 2022 and Revit 2022. Avoid !!
Nachricht 18 von 19
izzy_price1
Hi Everyone! I am looking for a new laptop for school that will run Revit and AutoCAD. I found a laptop and I was just wondering if anyone could tell me if it will work well. I'm on a bit of a budget because I am in school but I'm hoping this is a decent option. Here's the link: https://www.bestbuy.com/site/dell-inspiron-15-3520-touch-laptop-intel-core-i7-processor-16gb-memory-...
Nachricht 19 von 19
als Antwort auf: izzy_price1
For learning Revit and AutoCAD this laptop may be okay.  But don't expect it to handle decently any projects bigger than a house.
