Language may be selected twice
2 ANTWORTEN 2
Nachricht 1 von 3
b10830207
237 Aufrufe, 2 Antworten
I need Chinese to check my job, but sometime I need English to find.
Can I show two language at same time?
So I need this function.
Tags (1)
2 ANTWORTEN 2
Nachricht 2 von 3
ennujozlagam
als Antwort auf: b10830207
refer to this LINK and see if helps. thanks
Nachricht 3 von 3
RDAOU
@b10830207
On the File Menu >>> Go To Options >>> Spell Check >>> Switch Dictionary Between English and Chinese (List should contain the language packs/ .dic files you have downloaded/installed here C:\ProgramData\Autodesk\RVT 2022  )
So you swap to English ... find or spell check what is in English >>> then swap dictionary back to Chinese and Spell check what is in Chinese (Pretty much like word)
