Why haven't this Projects layout in my project?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
If you click on New, does it bring you to a list of templates? If so, just choose from there or click on Browse... to select your custom template. I don't know how to restore the list on the startup page with out a repair installation of the program.
Did you have it before? If this is a new installation then the content was not installed properly. You need to reinstall it and make sure the Revit content library and templates are included.
No, it is not.
Go to a drop-down menu under that little triangle, probably all localised libraries (for different languages) are checked by default, uncheck everything you do not want to install.
See your picture 3.png, at left of 'Autodesk Revit' while installing a program.
After I viewed the picrtur don't uundrestand have to do.
Sorry, I meant 2.png.
