HELLO, I SENT A PROJECT ON AUTODESK 360 BUT ON RENDERING THE REFLEXION ON WINDOWS IS ALWAYS BAD.THUS THEY ARE DARK.
THOUGH I PUT THE REFLEXION TO THE MAX AND CHANGED OTHER PROPERTIES . EACH TIME I RENDER ON THE CLOUD NOTHING CHANGES
HELPPPPP
Hi @Anonymous,
Did you check your settings of your rendering; your exposure is responsible for the settings for lighting. It can use the basics or it can use the settings you did set into your Revit File.
