Newbie here again...
I'm trying to edit a label in a sheet... but it doesn't show up, just a question mark...
I edit the family, ''edit label'', and put the ''sample value''... ''load into project''... ''Overwrite the existing version''...
and the changes doesn't show up... just a question mark when I select the sheet...
help...what am I doing wrong?
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
The question mark is asking you to manually input information. Is it editable?
Can you share the family?
It's a simple family sheet... but I don't understand why the labels doesn't work ![]()
Did you also want to edit the Nombre del disendaor?
I can easily change ''nombre del diseñador'' and ''Nombre de proyecto''
and those changes appear in the project when I load this family ![]()
But the one that I'm having trouble with is with is the little one... the date ''febrero 16, 2017''
that one is a label...
but when I load it in my project it doesn't appear... just a blue question mark.
Btw... I have already put shared parameters... I understand this is necessary for putting labels, right? ![]()
I'm new to this program
You need to add that shared parameter to the project's sheet properties (thru Project Parameters) so you can assign a value to it in the project.
Go to Project Parameters and add new. Select your shared parameter from your shared parameter file. Then, on the right side, scroll down and check Sheets. Save and close out. Go to sheet view and look at its properties. Your shared parameter will be shown there.
Hello! Thank you for all of this - I have another question to further the discussion. I added the material to the project parameters - Great! But it still shows up as a "?" and ONLY shows when I select the sheet.... Why doesn't it show the "sample text" and why does the sheet just look blank until I select it?
Also, is there a way to make one label SYNC with another label? IE: I type in a revision description and it generates the date ONLY when I type something in?
Hi all. Same issue here, I created title block, put in shared parameters, added it in project parameters, 3 other parameters I did the same way, work. Also, the same parameter, but on different sheets works, but on one of the, just a "?" when I select it. Any help?
Loading the new parameters into the project
LINK TO THE ARTICLE: How to add custom parameters to a title block in Revit (autodesk.com)
