Labelling the elements in Revit and exporting the labels to IFC
1 ANTWORT 1
Nachricht 1 von 2
aagr657
194 Aufrufe, 1 Antwort
I have a Revit model of a building, which I am trying to convert into IFC. In the IFC, I want to identify somehow which items in the Revit model have what properties. I know IfcGUID can be used for that, but it is a very complex sort of notation. Therefore, I want to label the elements somehow, such that the labels are linked to the elements in IFC. The labels I intend are nothing but simple pieces of string that can act as a unique identifier for that particular element.
Is there a way to add labels to the elements so that they are linked to the elements when exported to IFC?
Best Regards,
Ajay
1 ANTWORT 1
Nachricht 2 von 2
Corsten.Au
als Antwort auf: aagr657
Hello
You will have to look into IFC export setting and pick things you want.
IFC Export SettingIFC Export SettingExport Revit propertiesExport Revit propertiesuse type names etc...use type names etc...
Corsten
Building Designer
