label text siye/font change
2 ANTWORTEN 2
Nachricht 1 von 3
cbAVCK7
134 Aufrufe, 2 Antworten
Hi, I have a question about revit families, I would like to create a family, which has labels, fx.: tag size: 2.5mm, but, I would like that to be changable, when I insert it to the project, fx.: from 2.5 mm to 3.5 mm, or something like this, Can you please solv this issue.
Thanks in advance
2 ANTWORTEN 2
Nachricht 2 von 3
Simon_Weel
als Antwort auf: cbAVCK7
That would be nice, indeed! But no, it doesn't work that way. You have to create labels for each text size and create a visibility parameter. Then create a Family Type for each text size and switch on the appropriate text size visibility parameter. It will be messy, depending on how many text sizes you need:
Nachricht 3 von 3
cbAVCK7
:D:D:D Messy? More than that :grinsendes_Gesicht_mit_lächelnden_Augen: But thanks for the answer, I think one more thing for them to fix or have an easy solution for  :leicht_lächelndes_Gesicht: BTW it looks like those infinitive mirrors :)Thanks for the replay and aswer :leicht_lächelndes_Gesicht:
