L1 to Ground Floor
1 ANTWORT 1
Nachricht 1 von 2
daria3399
275 Aufrufe, 1 Antwort
L1 to Ground Floor
Hello!
I just started using Revit2024 and I am used to having the Ground Floor (Gf) as my first floor of the building. Right now, Revit is showing me L1 instead of Gf and it's a bit confusing sometimes. Is there any setting to change the names of the levels or do I have to do it every time manually?
Thank you!
1 ANTWORT 1
Nachricht 2 von 2
jay_colcombe
als Antwort auf: daria3399
Yes, you can open the Revit Template and edit it here so it will be set for every New Project.
Revit Menu > Open Revit File and open the *.rte file format and then save after changes have been made.
Template are located at : C:\ProgramData\Autodesk\RVT 2024\Templates\
You can add it so its available at Startup - File > Options (this also shows current template locations)
Jay Colcombe
Autodesk Certified Instructor
