Keynote should have a search option
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
juan_co-op
499 Aufrufe, 5 Antworten
I wish there was an option when you are keynoting an element to just have search bar to find the keynote for that element. I don't enjoy having to sometimes guess where things might be in the keynote file or having to have the keynote file open so that I can search in it. Keynotes just seem to be a forgotten feature in Revit where there have been no improvements to it.
Tags (2)
5 ANTWORTEN 5
Nachricht 2 von 6
apjones
als Antwort auf: juan_co-op
I agree. You should add this to the Ideas List.
https://forums.autodesk.com/t5/revit-ideas/idb-p/302
Pete
>Please Accept as Solution and give Kudos as appropriate to further enhance these forums. Thank you!
Nachricht 3 von 6
SteveKStafford
Until then... Revolution Design's Keynote Manager provides a superior way to work with Keynotes. Perhaps its existence is delaying a better internal solution by Autodesk?
Steve Stafford
Nachricht 4 von 6
HVAC-Novice
You have to sort in your spreadsheet (I use Google sheets). I sort by discipline and then by what type of work.
A note about lighting control would be in " EL"  under " Control". At the same time you also can have your spreadsheet open in a separate monitor to better find things. You may add more tiers.
There is the ideas forum for proposing additional features. But the above method works quite well for ME. YMMV
Revit version: R2025.4
Nachricht 5 von 6
Alfredo_Medina
I agree.
As an alternative, I can recommend a third-party tool: Keynote Manager. It contains a search box plus many other features that facilitate the work of editing the keynote file.
Nachricht 6 von 6
handjonathan
Hi @juan_co-op
Thanks a lot for posting your question to the forums!   Has the solution suggested by @apjones @SteveKStafford @HVAC-Novice @Alfredo_Medina helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
