Keynote schedule acting weird when it is filtered by sheet
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
sleeYUZCL
288 Aufrufe, 5 Antworten
I have this problem with only one project that when keynote schedule is filtered by sheet, texts go outside table. It only happens with one project. Other revit files work perfectly fine with filtering by sheet.
Does anyone have same issue or know how to fix it?
below is snip of keynote with filter by sheet on and off.
5 ANTWORTEN 5
Nachricht 2 von 6
syman2000
als Antwort auf: sleeYUZCL
Can you check the font used for the body of text? It seems when you don't have them filter, the text look small. Once filter, the text become larger.
Nachricht 3 von 6
sleeYUZCL
als Antwort auf: syman2000
Font and size are same when filter is applied.
Nachricht 4 von 6
syman2000
Try highlighting the schedule and click on reset.
If that didn't work, check and see if you have the latest Revit update.
Nachricht 5 von 6
sleeYUZCL
Omg this fixed the problem immediately. You saved me! Thank you so much!
No one in my office ever had same issue and we didn't know how to fix it while running out of space on sheets due to lengthy keynote schedule.
I really appreciate you help!
Nachricht 6 von 6
scottJUJ3Y
I have the same problem, but by hitting the reset buttone it changes the text size back to 1/8" Arial. Our company standard is 3/32". After I click the reset button and change the tex size to 3/32", the funny behaviour returns. Whats even stranger is when I deselect the "Filter by Sheet" option in the Filter settings, the behavior goes back to normal (albeit the keynotes themselves are wrong).
