Keynote Rotation
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
kjskoog
2134 Aufrufe, 6 Antworten
Keynote Rotation
I rotated the True North and Project North Orientation on a project I am halfway done working on. Noticed the keynotes also rotate so the annotation is reading at 90 degrees. All other annotations rotated except the keynotes. How can I rotate all keynotes without selecting each one?
Thank you in advance.
Kory Skoog
Project Manager/BIM Specialist
Kory Skoog
PM/BIM Manager
6 ANTWORTEN 6
Nachricht 2 von 7
dferreira-blackwell
als Antwort auf: kjskoog
https://forums.autodesk.com/t5/revit-api-forum/find-all-sheets-with-a-particular-keynote/td-p/548664...
Refer to the above thread for selecting all keynotes then maybe you can modify it according to your needs.
Nachricht 3 von 7
joe_keogh
Hi @kjskoog
If you select one of the Keynote Tags, Click Edit Family, you can check if the option, "Rotate with Component" is Checked, if so Un-check and Load into family.
Joe Keogh
Director | Design Technology + Innovation
www.viewlistic.com.au
Nachricht 4 von 7
kjskoog
als Antwort auf: joe_keogh
Thank you for the reply. There was no "Rotate With Component" under Edit Type. I may go into our Keynote family and see if I can make a parameter to rotate.
Kory Skoog
Kory Skoog
PM/BIM Manager
Nachricht 5 von 7
joe_keogh
Hi @kjskoog
Have a look here
Joe Keogh
Nachricht 6 von 7
joe_keogh
you will definitely need to Edit the Family.  I wasn't talking about Edit Type.
Joe Keogh
Nachricht 7 von 7
kjskoog
That was it. Found out the keynote was created under Generic Annotation and not Keynote. Also added to my confusion. Thank you!
kory Skoog
Project Manager/ BIM Specialist
Kory Skoog
PM/BIM Manager
