Hello, try to do the keynote command to label a roof.
After find the location file to charge to have the label now the command run but when use have symbols referring to the element, not the extended writing.
There is the possibility to change as attachment 2?
Thank's
Gelöst! Gehe zur Lösung
Gelöst von Mikael_QUIJADA. Gehe zur Lösung
Hi ![]()
https://www.youtube.com/watch?v=69bsbMWcnfE
Thank's very much!
This is the solution.
Have only an other question if is possible.
Trying to mark the walls in comment voice in propeties (as in the attachment ) to have what I write ("wall by project") in a tag .
I watch a video in which is use muticategory tag command to have this but I have not the correct match between what I write in comment ("wall by project") and the tag (have a question mark as result on the screen.
Maybe I haven't in revit the right tag in project? If click on tag by category command say me there's no tag charged in project.
If is for this someone say me where is in US (imperial or metric)libraries..? I don't find till now.
Someone say me something?
Thank's!
Here you have RevitKeynotes_Metric.txt (I don't have Imperial files)
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you.
@Mikael_QUIJADA thank's.
This is the solution for second question think.
https://forums.autodesk.com/t5/revit-architecture-forum/multicategory-tag/m-p/7271834#M158081
Thank's for RevitKeynotes_Metric.txt.
Have a good night! ![]()
