keynote 2d elements R24
12 ANTWORTEN 12
GELÖST
Nachricht 1 von 13
nferroKURZG
891 Aufrufe, 12 Antworten
Hi! I'm exhaustively trying to keynote a filled region but Revit 2024 does not grab it in any options available for keynoting.
I model a wall just beside it and it works...what am I doing wrong?
Btw, I did upload a keynote table w all the notes already..ty!
12 ANTWORTEN 12
Nachricht 2 von 13
als Antwort auf: nferroKURZG
Use User Keynote.
Nachricht 3 von 13
ralphdenhaan
As @ToanDN mentions use the User Keynote, for more info you could read this:
https://lazybim.com/keynotes-in-revit/#Keynotes-Types-in-Revit
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Nachricht 4 von 13
nferroKURZG
I did use the "user keynote" it attached to a 3D wall, but does not grab on the filled region..
Nachricht 5 von 13
nferroKURZG
als Antwort auf: ralphdenhaan
Hi Ralph, ty. I just went thorough your tutorial, very good btw.
It just does not recognize 2d elements when I hover it on top...so it's not working on 2d, only 3d elements :verwirrtes_Gesicht:
This is 2024 revit..
Nachricht 6 von 13
ralphdenhaan
It's not working on filled regions, but it is working on detail items (family).
Nachricht 7 von 13
ralphdenhaan
Try this family:) (see attachment) and you can set an Element/User Keynote for example.
Nachricht 8 von 13
nferroKURZG
Does not work with neither of these..
Nachricht 9 von 13
ralphdenhaan
Use the family in the attachment, it works.
Nachricht 10 von 13
nferroKURZG
didn't work too...
Nachricht 11 von 13
ralphdenhaan
Nachricht 12 von 13
nferroKURZG
Thank you very much, your family did work.
However, I still have to keynote lines in the model and the background plan that I inserted from autocad...keynotes still don't fully work..
Nachricht 13 von 13
You can just place ANY detail family, even with just an Invisible line, and User Keynote can recognize it.
