Hello all,
I am creating some structural walls. Is there any way to keep the instance properties ' Top constraint and offset ?
Each time that I create a new wall or Create Similar the Top constraint changes.
Thank you in advance!
it stays the even if I create a new wall from the structure tab or create similar:
Set your constraints and offset on the Option Bar. It will remain the default until you change it.
...doesn't look like a default "Offset" cannot be set. WTF! Betcha that Archicad can do it. Hear that Autodesk?! ![]()
