Announcements
How to make an imported jpg/png half-transparent?
dariawerynska
dariawerynska
I wonder if it is possible in Revit to make the imported image half-transparent?
I import the plan which I only have in .jpg and I need to have it in the background only little visible as it makes hard to build on it.
Just like using images in Autocad - first you make it less visible and then you draw.
Thanks!
Replies (9)
amorap
Hello from Spain
You can bring the image to the foreground or send it to the background, but in revit as far as I know, there is not posible to adjust the transparency.
Regards.
Augusto Mora
Architect & teacher of Building Projects at CPIFP Pirámide. Huesca (Spain).
Revit 2014 certified profesional.
Sahay_R
I'm with @amorap on this. Try to open the picture in Photoshop and adjust the transparency. If I remember rightly, you will need to save it to a TIFF to preserve the transparency.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Raster transparency doesn't work in Revit.  Once the image is in Revit, transparency is gone.
Sahay_R
And Revit can't import vector graphics from Illustrator. Rats. It was a great thought while it lasted! Apologies to the OP for attempting to lead him in the wrong direction.
Rina Sahay
Sahay_R
So an image can't be faded / greyed out either?
Rina Sahay
There is no such adjustments for images in Revit per se.  But you can place a semi-transparent masking/filled region over the image to screen it.
robk
Very clever and useful. Thank you.
dvowles519
This works while in Revit, but it does not preserve the transparency when you try to print. It's really frustrating when you want to print something to sketch over.    DEAR AUTODESK. PLEASE FIX THESE SIMPLE QUALITY OF LIFE ENHANCEMENTS THAT WE HAVE BEEN ASKING FOR YEARS ABOUT THAT ALWAYS GET IGNORED IN FAVOR OF SOMETHING THAT DOESN'T MATTER. WE DO NOT NEED ANYTHING NEW WE JUST NEED TO FIX WHAT WE ALREADY HAVE PLEASE
CEdwardsUN5MX
Asked for that years ago with Autocad...word came back from Autodesk via the reseller of the firm I worked for back then, will I please shut up.
