journal file error
210302256
journal file error
210302256
While I was doing my project I did not save my project and in that time my computer suddenly shut down. So,now I need journal file.When I try to open journal file it is working for a while and crashing somewhere I copied some curved wall. I tried to fix it with gpt but it did not help.I got
0EM3g000000gHkV.pngthis
Replies (8)
RDAOU
You were trying to fix what exactly with GPT? The wall or the Journal?
and did you consider opening a support ticket with autodesk? Or are u using an unsupported version of Revit?
I tried to fix journal file with gpt. And I am using revit 2025 student version.
RDAOU
@210302256
So that’s the file before or after the gpt attempt? and did you first try the steps described on the following link?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-restore-los....
I tried but couldn’t understand how to do that because I am not software engineer I don’t know how is wrong action or error message looks like in journal file
It should be main file(before gpt)
RDAOU
@210302256
ok I will give it shot when I get to the office but you should be aware that the chance to repair the data with journal files is very low. It doesnt always work
Okay, thank you so much !!
RDAOU
@210302256
Please check your inbox
