Attached is a photo of two joists which are several feet above the ceiling showing up in the RCP. This is only happening in this specific room. Can anyone help?
Is the ceiling object set as transparent?
They look half tone...Did you check the properties palette to see if you are you using underlays in those views?
Select the ceiling > right click > override graphics in view > by element > reset.
