Joist is not sitting on plate correctly
2 ANTWORTEN 2
Nachricht 1 von 3
gtdraftdesign
310 Aufrufe, 2 Antworten
Measuring a 9' PL ... roof set as using rafters ... but the 1/2" int wall finish is being used as the cutoff at 9' instead of the PL. Both stud and joist Core Boundary are Structure 1.
I've attached a snapshot which shows where 9' PL is and you can see that the PL is 1/4" below 9'.  Why?
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: gtdraftdesign
"Rafter" vs "Truss" (Roof Properties).
Nachricht 3 von 3
dan_SAA
For others searching, had the same problem, got help on Discord. When editing footprint of roof, make sure "Extend into wall (to core)" is checked. (As of Revit 2024 LT)
