Joining wall with cap to floor issue
4 REPLIES 4
mar_zan
322 Views, 4 Replies
I have a foundation wall with a 2x10 plate on it. I would like to join the wall to the floor above, but since the sweep is not treated as a wall it won't join properly. I would like to join them together so the linework makes sense.
So my question is, what is the most intuitive way to show a plate on a foundation wall for a construction set? Considering the sweep is not working.
EDIT: to clarify, when I say it won't join properly I mean the thick line wraps around the foundation wall and not the sweep. Ideally I would like the thick line to wrap around both (except for the join condition with the floor above.
Also, for those with experience. Perhaps I'm going about this the wrong way. I thought showing plate's in construction drawings (1/4"=1') would be useful information. Do others also do this? Or only show it in detail?
4 REPLIES 4
in reply to: mar_zan
- Stacked wall
- Wall sweep (placed manually)
- Structural framing
mar_zan
in reply to: ToanDN
sigh, ok. Yeah I knew about these but just wanted to make sure I wasn't missing anything. Thanks.
In your experience do you even show plates in a 1/4"=1' construction set? Perhaps I'm overcomplicating the drawings.
mar_zan
in reply to: ToanDN
Oh! I did learn something. I didn't know I could switch the variable part of a stacked wall. Which is why I didn't like it as a solution before.
Thanks for making this known to me
No, that level of details is taken care of by typical details.  But every firm is different.
