Good morning!
I am attempting to help a co-worker, who had created three identical walls, each topped by an identical sweep. When he joins all three walls together, the walls join seamlessly, but there is a line at the junction of each sweep. Looks terrible. Any solutions?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Added separately to each wall segment. Thank you!
If they are separate lengths on straight walls, omit all but one segment, select the remaining instance, drag its end to required length using the usual blue dot trick.
EDIT - wot he said! ^ ^ ^
Beautiful. Thank you!
And what about if the wall style was edited to add the sweep? The results look exactly the same.
Rats. Well it was a thought. Thank you!
