Joining Wall Sweeps
Joining Wall Sweeps
Sahay_R
Mentor Mentor
Message 1 of 8
Joining Wall Sweeps
Sahay_R
Good morning!
I am attempting to help a co-worker, who had created three identical walls, each topped by an identical sweep. When he joins all three walls together, the walls join seamlessly, but there is a line at the junction of each sweep. Looks terrible. Any solutions?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Replies (7)
Message 2 of 8
Are the sweeps built in the wall type or are they added on?
Message 3 of 8
Sahay_R
Added separately to each wall segment. Thank you!
Rina Sahay
Message 4 of 8
You can also delete two sweeps and stretch one to span the entire length.  Or simply delete two walls and make one wall longer.
Message 5 of 8
If they are separate lengths on straight walls, omit all but one segment, select the remaining instance, drag its end to required length using the usual blue dot trick.
EDIT - wot he said! ^ ^ ^
Message 6 of 8
Sahay_R
Beautiful. Thank you!
And what about if the wall style was edited to add the sweep? The results look exactly the same.
Rina Sahay
Message 7 of 8
If the sweep is built in the wall, then you are better off making one long wall instead of joining three.
Message 8 of 8
Sahay_R
Rats. Well it was a thought. Thank you!
Rina Sahay
