Joining vaulted ceiling component to walls
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
2403 Aufrufe, 7 Antworten
Hi all, I'm having some difficulty joining a vaulted ceiling component to the walls beneath it. On one side of the building I would like the ceiling to meet flush with the exterior wall and on the other side, I'd like the curtain wall to meet flush underneath it. I've tried to attach/detach but cannot seem to get it to work, any help would be greatly appreciated!
7 ANTWORTEN 7
Nachricht 2 von 8
Alfredo_Medina
als Antwort auf: Anonymous
  • For the vault, simply use the blue grip to move the end of the extrusion to the desired location, or use the align tool.
  • For the curtain wall element, use the Edit profile tool.
Nachricht 3 von 8
Are they roofs by extrusion?  From your picture, the profile edges of the roof are not parallel with the walls, so you need to cut the roofs with in-place voids.
Nachricht 4 von 8
als Antwort auf: ToanDN
Edit using the void worked a treat! thank you!
Nachricht 5 von 8
als Antwort auf: Alfredo_Medina
I've been trying to use the edit profile tool to match the curtain wall top to the curvature of the vault using the start-end radius arc. But it keeps telling me that my lines are intersecting. I'm probably not doing it right, I've attached screenshots of my process. Thanks!
Nachricht 6 von 8
PijPiwo
Sorry, but your approach won’t work. Either edit wall profile for one bay only and copy it over, or edit the profile for the entire wall (1st floor wall below the roof) so the edit lines don’t intersect, creating a loop instead.
Instead of drawing arches, use pick line option, faster that way :leicht_lächelndes_Gesicht:
p.s. Personally, I try to avoid in-place stuff whenever I can. Vertical opening tool will do the job as well.
Nachricht 7 von 8
als Antwort auf: PijPiwo
Cheers mate, one bay at a time was much easier! Just out of curiosity, how could I have barrel vaulted the ceiling like that without modelling in place?
Nachricht 8 von 8
PijPiwo
My bad …sorry, I’ve misread your post. I was under the impression that the vaulted object was a roof. My suggestion of using vertical opening tool instead of in-place void to cut the object was referring to the roof, not ceiling.
Vaulted ceiling needs to be done with in-place extrusion as you have it, and cut with the in-place void.
