I have created a roof and a floor (floor in this case is the final roof slab). Both types have the same hierarchy and structure. As you can see in the image attached below i want to join floor slab with roof, but it seems impossible. Is there any way to achieve the joint?
Thank you in advance
I did try that couple of times in different ways but structurally (in terms of how it is going to get build) can not be resolves as such.
Its never going to automatically wrap correctly between the two. you might have to edit the roof footprints slightly to get them to meet the right layers if that makes sense.
create 3 separate roofs then join them after you align them adjust the roof profiles to get the look you want
Or alternatively I don't the complexity of the rest of your roof structure but you could just do a roof by extrusion instead. See below
Can you model the entire thing as a floor (with slope arrows) or a roof?
